why overlook asa cam?
Old Aug 27, 2005 | 11:51 PM
Magnet's Avatar
Default why overlook asa cam?
it seems like everyone overlooks the asa cam and just hates on it...i dont see why from wat ive seen it only has very respectable number close to or above 400 reaer wheel cam only and you never have to change springs, it sounds frickin amazing, and has a torque curve like no other......so why does it not get any love???
Old Aug 28, 2005 | 12:05 AM
co.6z28's Avatar
better cams out on the market,pain in the *** to tune, bad drivability. im sure people will chime in with more reasons
Old Aug 28, 2005 | 12:06 AM
Nittany_marine's Avatar
Im interested too. I decided against it, and went G5X3, but I forget why I shyed away from the ASA.
Old Aug 28, 2005 | 12:14 AM
Magnet's Avatar
but once its tuned properly its a reasonably good driver right? if they can tune those massive cams to be good drivers i would think they can tune this cam too....
Old Aug 28, 2005 | 12:15 AM
DONAIMIAN's Avatar
Slow ramp rates rates, and most have heads that flow to .625.
Old Aug 28, 2005 | 12:16 AM
Magnet's Avatar
sorry im an idiot what does that mean
Old Aug 28, 2005 | 12:31 AM
co.6z28's Avatar
cam has low lift. its like .525 right?
Old Aug 28, 2005 | 12:45 AM
Magnet's Avatar
yea it has .525 lift.....so you can run ls6 springs which make the instal cheap and you wont have to change springs....thats what i reallly like
Old Aug 28, 2005 | 02:31 AM
co.6z28's Avatar
for the money a better cam can be bought. speed aint cheap,cutting corners usually cost u more
Old Aug 28, 2005 | 02:50 AM
DONAIMIAN's Avatar
The lobes on the cam arent as aggressive as most of the other aftermarket cams.
Old Aug 28, 2005 | 11:16 AM
Magnet's Avatar
so whats a comparable cam as far as hp, sound, and spring life??
Old Aug 28, 2005 | 11:47 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I would ALWAYS upgrade springs for any cam swap. I totally disagree with your statement.
Old Aug 28, 2005 | 12:06 PM
Magnet's Avatar
i meant you wont have to change springs every 15000 miles jsut from use....i know you have to change springs
Old Aug 28, 2005 | 01:23 PM
DONAIMIAN's Avatar
FWIW:I run a MTI T1(221/221) and put down 400rw. The springs have been on my car for over 35k miles.
