double roller chain - squeeling fan belts?
Everything checked out OK.
When I re-assembled the car, my belts started to squeel. This was a problem I had a few years back too but it eventually went away.
Question: Is it possible the double roller is causing the crank pulleys to not align?
I tried a new crank shaft bolt this week end and torked it 37lbs + 140 degrees - no help with the squeel, however.
