Is this beautiful or what?
Old Aug 31, 2005 | 06:57 PM
Order 66's Avatar
So does that just bolt up and how much more power over a LS6 intake.
Old Aug 31, 2005 | 06:59 PM
DONAIMIAN's Avatar
Originally Posted by mr2guru
Harrop Hurricane....
www.harrop.com.au
I'd LOVE to put that setup on my GTO...It's just too expensive.
That is a bad *** web site.
Old Aug 31, 2005 | 07:35 PM
Ed Curtis's Avatar
Cool
J-rod is very familiar with that system...
Drop him a note...
Ed
Old Sep 1, 2005 | 02:47 PM
GuitsBoy's Avatar
What do they use for an IAC if its got a throttle cable cam?
Old Sep 1, 2005 | 02:58 PM
ls1290's Avatar
Dumb Ass Vette Moderator
They have a drive by wire version also
Keith
Old Sep 1, 2005 | 05:07 PM
1FST99Z's Avatar
I would love to get my hands on one of these for a conversation piece. and to see what kind of power they make. weather it is more or less than a fast 90/90 setup.
Old Sep 2, 2005 | 05:59 AM
TUF383's Avatar
From the thread ...
https://ls1tech.com/forums/generation-iv-internal-engine/350199-ls7-c6r-velocity-stack-induction-injection.html
Quote:
Originally Posted by CAMN HAWK
what kind of gains did you guys see with the hurricane intake?
On a 383 with a mild street cam, typical increase over standard LS6 manifold is >40HP.
On a 427 with big heads & cam, we saw >70HP increase over a Fast 90.
Quote:
Originally Posted by ls1290
Would this fit/work with a C5? Keith
We have 1 guy who has fitted it to a C5. There was some interference with the cowl (which was trimmed) and the left air-pod needed modifying to fit around the power steering reservoir. I will try & find the photos (he is based in Germany!).
Quote:
Originally Posted by abadss
wow, that hurricane manifold is insane! like said before what kind of gains do you see with a 8tb setup? is it worth that much $$$?!!!
I guess the value is up to the individual to determine ... but the price for the cable-pull version manifold, with air-pods, is about US$3,600 including freight to anywhere in the US.
Quote:
Originally Posted by BUYAMERICAN
Hp & Torque (maybe 30 across the board)...yes...Looks great...yes...EAT MASSIVE AMOUNTS OF FUEL...YES...
It only uses as much as it needs to create the relevant power ... it is not much different (if at all) than the standard manifold for cruising ... the amount of fuel used is almost directly proportional to the gains.
Old Sep 2, 2005 | 06:33 AM
transam1998's Avatar
DANG!! I don't think I got that much increase out of my cam! That would probably rock with twin turbo or ATI twqin intercooled setup. Just run a pipe from each intercooler to each side of the manifold.
If I ever go 427 or f/I, I will seriously think of buying one of these. Heck, I'll probably buy one to hang on the wall.
http://www.harrop.com.au/root_folder...-amfd5314.html
These guys have a manifold that costs $8500.00
Old Sep 2, 2005 | 10:30 AM
Taspeed's Avatar
yeah, that has been my background now for about 5 months. I posted it up on here a while back and got almost no response, but by the time you ship it over and spend the time and money on the speed density tuning you will be out mucho $$$ and It will really only benifit you if you run a really low lsa cam with crazy duration. You can make a 104 lsa cam idle at 750 with the right tuning and individual TB's.
I am looking at fabricating an 8 TB intake using 8 42mm TB's from an early 2000's gixx. Should be a really nice setup with a lot of potential.
Old Sep 2, 2005 | 04:08 PM
topfuelman's Avatar
Default Indiv TB's
Do you have CAD skills to design a manifold to fit?
I was thinking a C.F. manifold with aluminum inserts at the flanges. Light, strong, not a heat sink, and can be molded into intricate shapes.
Would be a pretty cool collaborative project for the scientific advancement of LSx performance in North America! Let's start a volunteer sign-up of skilled/interested people!
T
Old Sep 2, 2005 | 04:24 PM
Taspeed's Avatar
unfortunately I do not have cad skills. I have always done things the old fashion way. Fabricate then test fit....make adjustments....test fit. Cuss and scream because it doesn't fit....then make some more adjustments.
I know it isn't the most technical way to design something, but it can be effective, and hopefully then taken to someone with the correct machining skills and design skills to really refine it into something affordable and functional on a larger scale production.
Old Sep 2, 2005 | 06:06 PM
  #32
Order 66's Avatar
30 hp gain on a 383. Lets get some more tests done!
Old Sep 2, 2005 | 06:37 PM
  #33
TUF383's Avatar
We also have a carbon-fibre unit for the C5R for ~US$10,250 ... we have built and supplied 5 or 6 of them over the past 2 years.
No-one complains of the price when they get the results.
Old Sep 2, 2005 | 06:39 PM
  #34
TUF383's Avatar
I can post some dyno results of the comparison if there is a host available ... ??
Old Sep 2, 2005 | 07:41 PM
  #35
topfuelman's Avatar
Default Hosting
Send the files to me and I can upload them to a host I am using.
If you want, send the description for each graph and I'll post the whole thing in this thread with links to the graphs!
I'm very curious about the indiv TB's and have been considering buying a set-up for our 383. Running the ls6 man + a ported stock tb for now with mediocre results.
Thanks,
Trev
Old Sep 2, 2005 | 08:24 PM
  #36
99SS-T's Avatar
They have a intake on that site that is 14k!!! It is beautiful but how can that be necessary? Insane.
John
Old Sep 3, 2005 | 07:44 PM
  #37
TUF383's Avatar
Originally Posted by 99SS-T
They have a intake on that site that is 14k!!! It is beautiful but how can that be necessary? Insane. John
That's $14k Aussie = ~$10,500 US.
We built this at GM's request for some of their race programs. They were VERY happy.
Old Sep 3, 2005 | 07:45 PM
  #38
TUF383's Avatar
If you want, send the description for each graph and I'll post the whole thing in this thread with links to the graphs!Trev
Thanks ... I will send you them next week ... have them on the work server & I'm at home now.
Edit ... Sent email 05 Sept.
Old Sep 4, 2005 | 12:27 PM
  #39
PREDATOR-Z's Avatar
It will eliminate #7 and #8 starvation.
It will make a 240 duration 106 ICL cam idle like a 224/ 114lsa
No more need for MAF crap.
I say yes it is worth the money.
Old Sep 4, 2005 | 12:36 PM
  #40
Rudolph's Avatar
That thing looks awesome, but i think you pay more for how it performs than for how good it looks, maybe i am wrong. Anyway, good looking
I know a lot of people that would pay for that marvelous intake
