G5X3 and Patriot Heads
Old Sep 1, 2005 | 05:23 PM
john59's Avatar
Default G5X3 and Patriot Heads
Hi Guys,
Are any of you running a G5x3 on a 114 with Patriot Heads LS6 style stage 2 with .02 Intakes? I was thinking about picking up a set from Gunner but am afraid I'll run into Piston to valve clearance problems
thanks
John
Old Sep 1, 2005 | 07:01 PM
john59's Avatar
ttt
Nobody running this setup??
Old Sep 2, 2005 | 07:35 AM
demonspeed's Avatar
It's not mine! woo hoo!
You'd be best to ask him and see what he has to say.
Old Sep 2, 2005 | 02:44 PM
yak's Avatar
yak
Is your x3 on a 114 or a 112. If it on a 112 I am sure it will not clear. I prolly won't on a 114 either.
Old Sep 4, 2005 | 05:25 PM
Nittany_marine's Avatar
You should probably flycut. I am going to on my AFR's I just got with that same cam on a 114.
Old Sep 5, 2005 | 10:21 AM
JZ'sTA's Avatar
Even if it would clear the first slight overrev and you tearing **** back apart.
Old Sep 5, 2005 | 10:48 AM
eamador11's Avatar
You dontneed to flycut with AFRs with the G5x3. Call TTP Performamce in NJ and they will advise the same thing.
Old Sep 12, 2005 | 02:12 AM
I know he doesnt "need to", but I say better safe than sorry....
Old Sep 13, 2005 | 03:10 PM
john59's Avatar
Thanks for the info Guys.
John
