Crank clearance
Old Sep 3, 2005 | 11:57 AM
Mr. Luos's Avatar
Default Crank clearance
How much clearance between the crank and the deflector/windage trey is needed???
Is this good?
Motor is at TDC. It looks as though the Eagle 4" crank clears easily.
Sorry for the crappy pic....old camera.
Old Sep 3, 2005 | 01:05 PM
strokedls1's Avatar
It looks ok. I just spaced it up a bit more with some arp washers that I had left over. Seems like you have ok clearance as is.
Old Sep 3, 2005 | 05:19 PM
lsx24's Avatar
Looks good to me, as well three things to check are from side top side. Closer to might be ok.
Old Sep 3, 2005 | 11:13 PM
racecar's Avatar
Looks good, as long as it cannot vibrate and touch the crank.
Old Sep 4, 2005 | 12:46 AM
lsx24's Avatar
I would check the left side claerance, looks tight.
Old Sep 4, 2005 | 09:54 AM
Mr. Luos's Avatar
The pic makes it appear closer than it is. I think I will go with some thin spacers just to be safe.
Thanks guys!!!
Old Sep 4, 2005 | 10:37 PM
Mr. Luos's Avatar
Well, I tested it today. Got some washers (1/16") and tightened the tray down.
The rod bolts are SO close to hitting the tray it isn't funny.
What else would I have to watch if I spaced it 1/8"?? Would it be easier to kinda knock out the 3 spots that come close with a ball hammer or something??
Old Sep 4, 2005 | 11:00 PM
Beast96Z's Avatar
I used ARP washers also. There .120" thick for refrence.
 Michael S. Palmer
Old Sep 4, 2005 | 11:04 PM
Mr. Luos's Avatar
What crank do you have, and how much clearance on the rod bolts do you have?
Old Sep 10, 2005 | 11:28 AM
Mr. Luos's Avatar
I can't seem to find a part number for the ARP washers.
Are these something I can order from a sponsor??
What about cheap washers from Home Depot or something??
Old Sep 10, 2005 | 11:52 AM
WAHUSKER's Avatar
The ARP washers come as part of the ARP main bolt (stud) kit. You should be able to use any washer that gets you the same spacing....I will be doing the same thing this afternoon.
Old Sep 10, 2005 | 12:18 PM
Mr. Luos's Avatar
How much clearance needs to be there between the rod bolts and the tray??
Using one 1/16" washers, the bolts come VERY close to the tray. Using two 1/16" washers clears it pretty easy.
I guess I am asking how much 'stretch' could the crank and rod bolts have while spinning in the upper RPM's???
