carbon deposits on pistons
Old Sep 4, 2005 | 07:20 PM
jaredm's Avatar
Default carbon deposits on pistons
took my heads off today (comp replacement lifter install) and all of my pistons where scortched with HUGE carbon deposit, enough to raise the surface of the piston. the car only has 35k miles but has been ticking pretty bad for a couple of weeks. I suspected a lifter but not this. I really don't think thats normal, I've seen pics of LS1's apart with more miles and less sh*t in them. whats going on?
Old Sep 4, 2005 | 07:54 PM
glennhl's Avatar
Does your engine use a lot of oil? We had the heads off my son's LS1 and the top of the pistons were pretty clean, just a light coating of carbon. You may want to try a catch can to keep the oil out of the intake track.
Old Sep 4, 2005 | 08:29 PM
Order 66's Avatar
Carbon build is normal. Just clean them off if you want.
Old Sep 4, 2005 | 09:33 PM
firefighter's Avatar
check your valve guides on old SBC's they'll cause that. I just pulled an old 350 apart yesterday and it was the same way and the guides are worn to hell.
Old Sep 4, 2005 | 09:35 PM
mr2guru's Avatar
There is a lot of carbon build up because of the crappy stock quench. You won't see near as much on a tight .030-.035 quench
Old Sep 5, 2005 | 08:03 PM
jaredm's Avatar
thanks for the reply's.here's a couple pictures , i already cleaned off a lot of the build up from the pistons before these were taken....nevermind , pics are too big , i have to figure out how to make them smaller first..
Old Sep 5, 2005 | 10:30 PM
SSDoubleK's Avatar
Good post, you just answered my question, my piston tops have alot of carbon buildup also, I believe alot of that is normal, I've thought though running a 160TStat keeps the motor cooler, so it can't heat up as much to burn alot of that excess off. My two cents.
Old Sep 5, 2005 | 11:04 PM
dame's Avatar
wanna know how i keep my top end clean?
150 shot once a week
Old Sep 5, 2005 | 11:43 PM
s346k's Avatar
"wanna know how i keep my top end clean?
150 shot once a week"
that should be on a shirt..
Old Sep 6, 2005 | 06:39 AM
roadrash9r's Avatar
had alot on mine, used a scotch bright bit on a dremmel tool and cleaned them up. Went with a commetic for a tighter quench.
Old Sep 6, 2005 | 09:46 AM
Rudolph's Avatar
Lots on mine, and when cam swap, i cleaned it up
I think that the catch can (mini air filter) is not working very good
Old Sep 6, 2005 | 12:45 PM
CAT3's Avatar
Restricted User
I think you meant H & C swap...if not you did the cam a long, hard way
I agree, oiling buildup, and quench height is an issues. Dealing with a buddy that has been troubleshooting odd KR, and my first guess is Carbon deposits. Hate to pull it apart only to clean the pistons and chambers
Old Sep 6, 2005 | 12:51 PM
Lasershop's Avatar
130,000 on the LS1 from my '97 Vette' when it was removed for rebuild. Very clean everywhere. Bottom end looked like new. Not much carbon on the pistons or chambers. Always ran Synthetic and changed often.
Old Sep 6, 2005 | 06:43 PM
Order 66's Avatar
That will do it!
Old Sep 6, 2005 | 07:26 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
LMAO And I thought top end cleaner was radical.
Old Sep 6, 2005 | 08:07 PM
SSDoubleK's Avatar
Gonna start using the synthetic oil. Anyway to smooth out those piston tops if your valve dented them a bit?
Old Sep 7, 2005 | 02:12 AM
CAT3's Avatar
Restricted User
Hopefully you fixed the root of that problem, but anyway...
1) you can scotchbrite the high sides and smooth it out some.
OR
2) rent a valve relief cutter and cut them in deeper.
Old Sep 7, 2005 | 02:54 PM
Rudolph's Avatar
Yup, you are right, H/C
