Getting Cam, What Computer Mods Needed?
im running the comp xe-r and it runs fine without any computer mods, if you get it tuned it will sound more like stop, but its definately not needed.
Don't even mess with a Predator tune or anything like that.
With some small cams like mine you can actually get away with a stock tune. Truth be known, my car drove better with less bucking on it's first tune (done by the same shop, but only for the headers, LS6 intake, ported tb) than it did after the tune done with the cam in the car.
Big cams definitely NEED a tune. I don't know the specs on your cam....it's called "extreme" must be big
Doesn't the new one have live data recording capabilities?
Then with that data you can get a custom diablo tune.
But just by the way you asked the question, I can tell you do not have much experience with motors. Who is going to do the install for you??
But BTW XE-R lobes are just steeper to open and close valves quicker, which gives you more trq down low and a little broader range on top.
you can have that cam on a 114.
I have a 224/220, .581/.581 116lsa +0 (Stealth) so I can assure you it is no problem on the street.
