How high in the RPM range with this Cam?
Old Sep 7, 2005 | 09:45 AM
beardWS6's Avatar
Default How high in the RPM range with this Cam?
I have 232 234 598 598 114 lobe. Car in Sig! What do you think my top RPM range will be. Reason I ask, mine is a A4 and I want to adjust my shift points and window pills for my spray just right. What do you fellas think they should be. I`m going to tune Friday with the set-up in my SIG. I just changed cams. I had a Y1 and it didn`t like the A4 much. Thanks for any info fellas!!
Old Sep 7, 2005 | 09:59 AM
777's Avatar
777
You won't know for sure until you get it on the dyno. I'd have to guess it would be around 6300-6500rpms.
