hows this setup for my future 98 z28.
-SLP zl402 short block low compression 9:1 compression
-AFR 225cc heads with rev kit and roller rockers
-procharger d-1sc kit with new bigger intercoolers
-comp cams XR269HR-14LS1 Hydraulic roller camshaft .525/.532 lift with 114 degree seperation 1300-6300 rev kit
-quicktime performance headers and timing chain cover with larger oil pump
s-lp heavy duty timing chain
-fast 90/90 set up with ls1speed fuel package set up thinking about buying fast fuel rails intead of the ls1speed ones.
-Be cool radiator to cope with the procharger overheating problem ive heard about.
-going to upgrade to 55 lbs injectors from the 45 lbs ones that come with the procharger kit
-Borla cat back exhaust
-MOser 12 bolt with posi and 33 spline axles and carbon fiber drive shaft
-msd blaster coils with msd wires and NGK TR6 plugs fir a cooler spark
- i plan on installing a full BMR chassis setup later on.
Thanx
