Some Problems with my car...
SINCE that run, car's been acting funny. It has started surging after you come off throttle and put it into neutral. Started doing it in the staging lanes so I left and quit for the night.
It's still doing it today. When you start it it finds idle fine, and turning AC just moves it to a higher rpm. But it's after putting it in gear and moving, then putting the clutch back in, it starts surging, and doesn't want to stop. With the AC on it's worse, it surges a lot.
If you've got the AC on and come to a stop, it surges like crazy down to like 200-300 rpm, and the oil pressure drops with it as well, then swings back up. If you flip the AC off it stops and comes back to idle.
Anyone have any ideas of stuff I should check? Or what could be causing it?
