will lifters cause misfires??
Old Sep 12, 2005 | 01:48 PM
ninobrn99's Avatar
Question will lifters cause misfires??
Im going to try to swap coil packs again and this time monitor the misfires with efi or tuners, but i would like to know if lifters are also a culprit that could cause misfires on 2 cylinders...
Old Sep 12, 2005 | 05:56 PM
ninobrn99's Avatar
this should be an easy one fella's...please help a brotha out!
Nino
Old Sep 12, 2005 | 07:57 PM
defaultexistence's Avatar
Default missfire
i've caught missfires due to bad injectors,bad plugs,bad gapping on plugs,bad plug wires,or plug wires not connected properly ,...8.5mm MSD wires RULE!..hope that helps,mike
