1998 rocker arm problems?
Old Sep 13, 2005 | 02:41 AM
nrayome98TA's Avatar
Question 1998 rocker arm problems?
Just found needle bearings in my oil this past weekend. Time for new rockers. I was searching and came across a thread saying there are a lot of problems with aftermarket rocker arms fitting 98's? How much of a pain in the *** is this going to be to me? I think I'll just go with the reworked stock ones from Nasty performance. Anyone else have experience w/ this problem? Sorry for the book, any help is appreciated. Thanks
Old Sep 13, 2005 | 06:35 AM
SAM98WS6's Avatar
No problem at all with aftermarket fitting...they are all the same. Valve cover clearance is an issue with some..but nothing a little rework wont fix.
All years of LS motors have junk stock rockers and they should be replaced if they are going to be used hard.
Old Sep 14, 2005 | 11:16 PM
Thanks, anyone else?
Old Sep 14, 2005 | 11:22 PM
bmfcamaro's Avatar
98 had different valve covers. i believe any aftermarket ones will hit the pcv under the valve cover. you can grind on it though or get spacers.
Old Sep 15, 2005 | 02:40 AM
My valve covers are perimeter bolt and the spacers I found are center bolt. Are there perimeter bolt spacers?
Old Sep 15, 2005 | 05:03 AM
LS1FIRE's Avatar
Yes they are perimeter bolt spacers for 98s. Some company on ebay sells them new for a good deal go search around.
