First Cam Swap - HELP
You are supposed to spin the cam for the lifters to go up in the cups, then insert the dowels.
I dont know what the deal was. I just wanted to try them out to see how easy it made it, but it was being such a PITA i didnt bother. Im not trying to be rude
So hows the UAE?? still hot?? been about a year since i was there.
I can't wait to try my new goodies (PRC 5.3L stage 2.5) with a good little 200 shot dry
Firebirds and TAs are like really rare.
Most Camaros are 97 and older.
Ohh well, I get to spank all the mustangs by myself
I even got to spank a C6 just this week, should have seen the look on his face
was it an arab driving it or american??But i can say, I'm one of the toughest street legal ***** out there.
I do not know what he was, but i knew he was spanked
1) Should I remove the valve springs and rocker arms before I spin the cam and slide in the dowels? I think yes but I just want to make sure.
2) After installing the new cam... before putting the covers on, the chain on, and finishing the valve train, how do I make sure that it's timed correctly?
Thanks,
somebody
When you put the chain on that is when you time it. there are 2 dots that you have to line up darn near perfect. there is one on the cam sprocket and on the crank sprocket.
If you have a double roller chain, that makes it a little more tough to get that chain back on.
When your ready to swap the springs, you could use air in each cylinder by way of compressed air in the spark plug bore, or you can do it the smarter way and use top dead center for every cylinder - by using this way, there is no chance of a failure like using air. Any airline hose could have a rupture at a really bad time.
DON NOT PULL THE SPRINGS OFF UNTIL THE CAM IS IN AND YOU HAVE A WAY OF HOLDING UP THE VALVES!!!!
air is a perfectly safe method. tdc doesnt keep the valves from falling it just keeps them from falling too far. I've never in 30 years seen an air hose blow that was in good condition. Worn hoses just waiting to go will of course go. Replace worn tools as you would worn parts. Sorry but I've never seen the air hose paranoia before
its a perfectly accepted method. You forgot the nylon rope as well..
