Help! Pin in oil!!
Old Sep 16, 2005 | 04:09 PM
98BirdLS1's Avatar
Default Help! Pin in oil!!
I changed my oil today, and when I pulled the oil plug this little pin pictured below was attached to the magnetic part along with some metal shavings.
What the hell is it? I have no SES light, oil pressure is great, temps are great, car runs great. Recently my valvetrain noise got a bit louder but I thought it was just because I had my headers flanged and they were leaking.
My car has a hotcam/LS6 springs, stock pushrods, stock rockers and full bolt-ons.
Please, any help you can give me would be great.
Luke
Attached Thumbnails Help! Pin in oil!!-pin-pencil.jpg   Help! Pin in oil!!-pin.jpg
Old Sep 16, 2005 | 04:23 PM
kenSS's Avatar
97-99 ls1 were known for this. the pin came from one of your rocker arms. I would upgrade to the newer rockers, GM supposly got rid of this problem.
Old Sep 16, 2005 | 04:26 PM
Brandon Boomhauer's Avatar
just find a newer set of stock rockers and you'll be good to go!
Old Sep 16, 2005 | 04:27 PM
98BirdLS1's Avatar
Thanks man. I called my tuner and asked him, he diagnosed the problem just about as fast as you did. Harland sharps are on the way.
Does anyone know if I have to grind my valve covers for the Harlands to fit on a 98 car?
Old Sep 16, 2005 | 04:28 PM
turbotacoma's Avatar
Yes you will and you may need to grind the heads too!!! I recommend going with a 1/4 or 1/2" spacer instead of grinding the valve covers. I this first hand.
Old Sep 16, 2005 | 04:30 PM
kenSS's Avatar
this might save you some money, but from what i was told by mikey from rapid motorsports, he said the stock rockers actually make more power than the adjustable roller rockers. plus the stock ones are quieter.
Old Sep 16, 2005 | 05:26 PM
98BirdLS1's Avatar
Stockers are a bit more expensive that the Harlands, I wanted to get a reworked stock set from Nasty Performance, but I couldn't get a hold of anyone there, and I was concerned about the turn around time.
I will look into the spacers, who makes spacers for Perimeter bolt valve covers??
Luke
Old Sep 20, 2005 | 12:17 PM
triumphman's Avatar
if the pin mikes .250 it came from your cam[alignment dowel] chances are the sprocket is loose and a disaster is looming.pull it apart immed.
 Michael S. Palmer
Old Sep 20, 2005 | 12:31 PM
BOONE's Avatar
I agree that its not from the rockers its too big.
Old Sep 20, 2005 | 01:25 PM
PREDATOR-Z's Avatar
Compared to the pencil, that does look big for a rocker bearing.
Old Sep 20, 2005 | 02:28 PM
Tony Mamo @ AFR's Avatar
Flow Wizard
Might be the pin in one of the axle wheels of a roller lifter....
Check for excessive play in one or more of your rocker arms. You did mention increased valvetrain noise.
Tony M.
Old Sep 20, 2005 | 03:22 PM
Krab's Avatar
It's just an extra part when they assembled the engine from the factory. You know, like when you have to assemble a desk or something, you always have left over parts.
Seriously though, it does look too big to be a roller bearing from one of your rocker arms. Why don't you take them off and inspect them to be sure? That will rule one thing out.
Old Sep 20, 2005 | 04:08 PM
98BirdLS1's Avatar
How big should a bearing from the rockers be? I thought it was rather thick to be a bearing in something as small as a rocker.
If it as the alignment dowel, what would cause that to break off? And what would be my measure to fix it? I would hate to thing I wasted 400 dollars on HS rockers to fix something that wasn't broken.
Luke
Old Sep 20, 2005 | 04:15 PM
calongo_SS's Avatar
I agree as well, I don't think it's a rocker arm needle bearing. What it is, I don't really know. Tony M. may be on the right track. I'd check out the valvetrain, since you're getting more noise from there.
Old Sep 20, 2005 | 05:00 PM
Elite_Hot_Rod's Avatar
A rocker arm needle bearing is smaller in diameter than the lead on a #2 pencil.
Luke
Old Sep 20, 2005 | 05:06 PM
98BirdLS1's Avatar
[IMG][/IMG]
That is most certainly not what I found on my oil plug. Mine was about that length, maybe a little bit longer. But alot thicker in diameter, close to the thickness of a pushrod.
How the alignment dowwel dowel come off? And does this mean I have to get a new cam? Help, Help, Help. I need this car for school tomorrow.
p.s. Good to know my 400 dollars was wasted.
Luke
Old Sep 20, 2005 | 05:16 PM
Flow Wizard
An alignment dowel is unlikely and would not cause additional valve train noise. CHECK your valvetrain for signs of lifter related issues....its the next logical route to take in the process of elimination.
Old Sep 20, 2005 | 06:26 PM
72ChevelleConv.LS1's Avatar
Don't drive the car tomorrow. find out what is wrong then fix it. this will coust you far less. remove the wiers, coil packs and valve covers. look hard at the rockers, shake them move them and see if one feels weird. if you dont mind making a mess, (oil shooting out),start the car for a few sec.s and see if things look odd on one rocker. this will give you somthing to do tonight just to get a head start. Don't drive it till you find out what is wrong.
Old Sep 20, 2005 | 09:54 PM
98BirdLS1's Avatar
Bump.
Got the rockers out. Couldn't tell anything was wrong with any of them. Pushrods are all straight. Nothing suspicious with the valvetrain. All the valves are at the same height.
If the timing sprocket is loose, how would that happen? The three bolts that are in the cam are coming lose? I've been going through searches and searches and I can't find a thing.
p.s. The Harland sharps are going to need alot of clearancing on my heads. I'm gonna be up all night. PLEASE HELP.
Luke
Old Sep 20, 2005 | 10:19 PM
I gotta think it's a lifter wheel pin.
