VHP/Crane Cams Spring tool?
Old Sep 19, 2005 | 07:48 PM
JNorris's Avatar
Moderator
Question VHP/Crane Cams Spring tool?
Will the VHP/Crane Cams Spring tool work on Comp 987 springs?
The 987 dual springs are 1.43” O.D. so there will be .13” less room between the springs than with other dual valve springs which are 1.29” – 1.30”O.D.
Thanks
John
Old Sep 19, 2005 | 07:52 PM
NC98Z's Avatar
probally but the MORE TOOL kicks ***.
Old Sep 20, 2005 | 07:22 AM
Z'mnypit's Avatar
Just make you one. Thats what I did. Do a search on the Larry tool. Its worked just fine so far. Not to long ago someone on here posted pics of a new tool that would do two springs at once. That would be the way to go.
Old Sep 20, 2005 | 08:22 AM
JC5's Avatar
JC5
The arm on my Crane compressor is .600 so slight interference!
Old Sep 20, 2005 | 09:32 AM
JNorris's Avatar
Moderator
That is good info. Now if I knew the distance from the center of the exhaust valve to the center of the intake valve then I would be set.
John
Old Sep 20, 2005 | 11:03 AM
vettenuts's Avatar
I just installed my VHP/Crane springs with this tool a few days ago, as I remember it was fairly close with the Crane's, not sure you will make it with the larger diameter. Call Joe or Roger Vinci and verify for sure.
Old Sep 20, 2005 | 11:18 AM
SideStep's Avatar
I have that tool.. I tried to use it with 1.43s and it did not work. The spring bound against the side of the tool....
Old Sep 20, 2005 | 11:25 AM
JNorris's Avatar
Moderator
Dang! Not what I wanted to hear. What spring tool did you use to remove the 1.43 springs?
John
Old Sep 20, 2005 | 12:32 PM
SideStep's Avatar
John
I used this one from NAPA, $35
Old Sep 20, 2005 | 01:13 PM
JNorris's Avatar
Moderator
So that puller was able to compress the dual valve springs?
John
Old Sep 20, 2005 | 05:12 PM
SideStep's Avatar
John
Yes, it did... if you get the one with longer hooks, it will reach into both springs.
Old Sep 20, 2005 | 05:36 PM
mrr23's Avatar
i wouldn't try to use that on a f-body though. cylinders 7 and 8 are under the cowl. most likely too tall and will hit the cowl. another question i have is why such large springs? does the G5X1 need that much spring?
Old Sep 20, 2005 | 05:57 PM
JNorris's Avatar
Moderator
No the G5X1 does not need that much spring but the Comp. 987 dual springs are what came on my TEA heads so that is what I used.
The heads/springs only have about 3,500 miles on them but as part of regular maintenance wanted to pull a few springs and have them tested.
I hate that I just bought a spring tool that I will not be able to use.
John
Old Sep 21, 2005 | 12:47 PM
mrr23's Avatar
depends on where it actually hits the tool, you could grind down where the spring hits.
