Help...Ported and shimmed ls6 oil pump!
Old Sep 21, 2005 | 01:20 PM
camaross305's Avatar
Default Help...Ported and shimmed ls6 oil pump!
I found an ls6 ported, polished, and shimmed .100 . Im putting in a f13 cam, intake, ls2 timming chain etc. stock bottom end. WIll this pump be ok for my application or will it being shimmed harm my motor or cause leaks? Or should i just keep looking for one that is not shimmed?
Old Sep 21, 2005 | 01:27 PM
777's Avatar
777
shimming is just going to increase oil pressure. Basically the more oil pressure the better.
Old Sep 21, 2005 | 01:54 PM
co.6z28's Avatar
my oil prussure got a lot better with p/s ls6 pump
Old Sep 21, 2005 | 02:19 PM
GuitsBoy's Avatar
same here. Home ported / shimmed a new ls6 pump, and its doing very well.
Old Sep 21, 2005 | 03:28 PM
So i guess shimming isnt bad then......i heard somewhere on the board that it was bad for some reason on certain motors. So thanks guys for the help then!
Old Sep 21, 2005 | 04:21 PM
bowtieman81's Avatar
My 2 cents: shimming isn't necessary but won't really hurt you either. I just ported my own LS6 pump and put it in (really pretty minor porting), with no shimming. Runs 40 psi hot idle and 50-55 crusing down the road. Has 65 psi when I stand on it. I don't see needing more than 65 psi.
