Installing a new cam
Old Sep 22, 2005 | 05:58 PM
02' hawk's Avatar
Default Installing a new cam
I am about to install a new cam tomorrow. Should i use assembly lube on the new cam or just use oil?
Old Sep 22, 2005 | 06:02 PM
LoPeY's Avatar
Just drench the cam in motor oil.
Old Sep 22, 2005 | 06:26 PM
Sabre002's Avatar
Cam lube man use it then brake the cam in and change the oil.
Old Sep 22, 2005 | 06:42 PM
02' hawk's Avatar
Well shouldn't the cam of came with lube?
Old Sep 22, 2005 | 08:51 PM
Flawless02SS's Avatar
Def use some assembly lube!! Engine builders use it for a reason!
Old Sep 22, 2005 | 08:56 PM
kenp's Avatar
I agree with LoPey. You don't need assembly lube with the roller lifters. Oil is all you need.
Old Sep 23, 2005 | 04:31 PM
98LS-WON's Avatar
What he said.
Old Sep 23, 2005 | 04:53 PM
T-maxx's Avatar
No lube, just oil. What cam did you go with?
Old Sep 23, 2005 | 08:29 PM
uberLS-1's Avatar
Originally Posted by 98LS-WON
What he said.
Also agreed, but some engine builders still put assembly lube on, ONLY ON THE CAM LOBES, not the bearing journals. If this is going back together right away and started I would only use oil, but if this might sit awhile, probably lube....oil will run off.
Old Sep 23, 2005 | 09:12 PM
Stark's Avatar
oil is fine. Ram it in, fire her up!!
Old Sep 23, 2005 | 09:58 PM
vettenuts's Avatar
I used the Redline lube in a few places, tips of push rods, chain damper, aid to install o-ring (hope I got that right, my startup is tomorrow). The Redline assembly lube has no moly and disolves very quickly into the oil.
Old Dec 2, 2005 | 07:39 PM
02' hawk's Avatar
Thanks.
Old Dec 2, 2005 | 08:47 PM
Var's Avatar
Var
I used royal purple assembly lube on my entire cam(lobes and journals), and on the valves seals and the valve locks. I haven't started it yet though.
Old Dec 2, 2005 | 09:24 PM
HOSS's Avatar
soaked mine in oil, its still running
Old Dec 2, 2005 | 09:53 PM
FstBlkz28's Avatar
Oil ... done two cars that way. No problems with either
Old Dec 2, 2005 | 11:18 PM
CBX's Avatar
CBX
Oil, get it covered well, It will do the job.
Old Dec 5, 2005 | 09:02 PM
02' hawk's Avatar
Yea no problem with the oil.
