Valve Seals
Old Sep 27, 2005 | 04:53 PM
02WS6Bird's Avatar
Default Valve Seals
Will be pickiung up a 99 Z w/ 114K on it for my project car...only motor problem is VALVE SEALS. so i need to know....how do i replace them....is there a right up? Pictures
etc?
Never done this before will be having my buddy who knows how help me but i jsut want to see how this is done on these cars if possible before hand...And i know the heads have to come off in order to do this.
How much do valve seals cost? How much for new head gaskets, and where should i get them if i even should? What else will i need i mean EVERYTHING? Thanks in advance!
Old Sep 27, 2005 | 05:42 PM
mrr23's Avatar
you can do them with the heads on the car. just need a valve spring compressor at a minimum. vinci sells a spring tool and air hose with adapter. it'll be the quickest and cheapest way to do it. no need to pull the heads.
http://www.vincihighperformance.com/superwebdeals.HTML
Old Sep 27, 2005 | 05:54 PM
98LS-WON's Avatar
Do a search for the "Larry Tool", i got one for $30 and it worked just fine. Hopefully you have an air compressor to make things go a lot faster.
Old Sep 27, 2005 | 05:58 PM
mrr23's Avatar
the vinci/crane tool is on blowout for $69.95 right now. normally $105.00 does two springs at once. the larry, john, mike, judge, etc... tool does only one at a time. and yes, an air compressor makes it alot quicker as well. some do the TDC method. either way, the spark plug comes out.
Old Sep 27, 2005 | 11:14 PM
ArKay99's Avatar
I just picked the tool up, well at the higher price with the air hose adapter. I also picked up a valve seal installer from Moroso, but you can use a deep socket. I shimmed my springs and changed the seals with this stuff in about 3 hours. I should have taken less, but didn't have any grease to hold the the keepers onto the valves when I relaxed the tool. So I had to redo the keepers a few times.
Old Sep 28, 2005 | 10:42 AM
GuitsBoy's Avatar
You can replace them without the air hose adapter using the TDC method. Check out lsihowto.com and see the cam swap.
Old Sep 28, 2005 | 05:45 PM
02WS6Bird's Avatar
https://ls1tech.com/forums/generation-iii-internal-engine/387306-diagnose-problem.html
