ANYONE HAVE THE SLP 402? tech ???'s inside
Old Sep 29, 2005 | 08:22 AM
Bryan @ Speed Inc.'s Avatar
Default ANYONE HAVE THE SLP 402? tech ???'s inside
anyone here have a 68cc head w/ 2.08 intake valves on top of the high comp motor??? what's the most lift you can run?
i have patriot stage 3 ls-6 heads w/ the 68cc chamber........ i believe the pistons have 6cc valve reliefs, but i heard there were some piston to valve clearance issues... who's having them???
i want to run a cam that has around .614 lift and want to make sure it'll be safe. i REALLY don't want to have to pull the heads off just to check p to v clearance.
thanks in advance guys!
Old Sep 29, 2005 | 08:55 AM
anyone?!
Old Sep 29, 2005 | 09:35 AM
JakeFusion's Avatar
Super Hulk Smash
You shouldn't have any problems with that. 1cc is about 80 thou, I believe. So 6 x .008" is plenty of clearance, because you need .008" - .010" minumum.
Old Sep 29, 2005 | 10:58 AM
thanks!!!
