more problems- need help!
Old Sep 29, 2005 | 02:52 PM
pdd's Avatar
pdd
Default more problems- need help!
drive along at 30mph and all of a sudden car starts making noises like i bent a valve. exhaust gets real loud and car goes into low power mode and i can only limp home at 20mph. i was only amile away from home. anyway i figured i broke a spring, i checked the springs and i doesnt look like any are broke. any ideas welcome
Old Sep 29, 2005 | 03:04 PM
NOSjohn's Avatar
Restricted User
It could be anything really. Bad MAF will induce limp mode. Have you done an preliminary testing? I know you've checked the springs but how about compression test? Does it start and run okay at idle with no load? Does it sound like it's mis-firing or does the car just bog when you step on the gas?
Old Sep 29, 2005 | 03:13 PM
nuzee's Avatar
Check your exhaust system for a leak. 1st thought would be header gasket. 2nd o2 sensor or header collector connection.
Old Sep 29, 2005 | 03:15 PM
LSUxBlake's Avatar
Did you check all your plugs, wires? Maybe a wire came disconnected.
Old Sep 29, 2005 | 03:26 PM
pdd's Avatar
pdd
it idles but it still sounds like i bent a valve sound. i checked the exhaust and plug wires-there ok. MAF looks good-its got the resistors in there. threres plenty of oil in the car. does it sound like a spun bearing??? christ i was babying the thing when it happened. how do i check the o2 senors for problems? could it be a bad lifter?
