ARP Head Bolts????
Old Oct 1, 2005 | 05:49 PM
LS1FIRE's Avatar
Ladyredhawk how many miles did you put on the car since you notice the leak? I just used ARP bolts in my H/C swap and drove aroudn 250miles with no leaks.
Old Oct 1, 2005 | 10:10 PM
Lady Redhawk's Avatar
From: sojourning....looking for my city whose builder and maker is God.
I have about 1,000 miles on them since they were installed 2 months ago. If it leaks with normal driving it isn't much and causes no smoking or any noticeable signs. Except it is slowing losing coolant. And then when I went to the track, the added pressure caused more of a leak. It must have already been low on coolant because at the track the first 2 runs seemed fine, however did notice it was running about 5-10 degrees warmer than normal. On the third run they had to wipe up a few drops of coolant from off the line my car had left behind. By the time I hit the return road I noticed the temp was going up to about 220 and by the time I got parked the temp went up to 245
