long blocks!!!!
Old Oct 4, 2005 | 06:04 AM
prostock_bigblock's Avatar
Default long blocks!!!!
who has the best and good priced longblocks?
what cubic inches do you all advise me to go for?
what are the advantiges geting an ls2 block over ls1/ls6?
Thanks
Old Oct 4, 2005 | 10:26 AM
DrkPhx's Avatar
Thanks
1) - Depends exactly what you are looking for; stock cube or stroker. Start some research by calling the sponsors on the right. >>>>
2) - There's no replacement for displacement, except when you are on a budget! Strokers are expensive, especially when you take in consideration upgrading the fuel system, drivetrain and suspension and related parts.
3) - Having the increased bore/cubes of an aluminum 6.0L block compared to the 5.7 block.
Ultimately you need to decide what your goals and intentions are, then research what motor and setup suits your needs, then see if it fits in your budget. Because money is the deciding factor what you can or cannot build.
Old Oct 4, 2005 | 10:35 AM
Blown408's Avatar
http://www.forcefedhighperformance.com/ --------->
call Brad, let him know what you are looking for and he will hook you up!
Old Oct 5, 2005 | 12:06 AM
thats what i am looking for , I did some research but I would really like some new updates ....
Old Oct 5, 2005 | 12:25 AM
Ferocity02's Avatar
Yes... we need to hear your goals! Super/Turbocharger? Nitrous? All motor? Street? Strip? Street/Strip? Daily driver? Reliable? Iron? Aluminum? Etc....
