Heads came in yesterday, a few pics
Old Oct 4, 2005 | 02:14 PM
TSDuke's Avatar
Default Heads came in yesterday, a few pics
Well, it took 5.5 weeks for them to come in, but I'm happy with the outcome so far (#s to come). Precision Porting stg 3, with thermal coating to cumbustion chambers & valves. PRC Gold dual valve spring kit. Here are a few pictures.
The rest of my setup is: LGM G5X3 114, LS6 intake, LS6 oil pump, Double roller, 160* stat, Trick Flow hardened pushrods, 36# injectors....
Old Oct 4, 2005 | 02:20 PM
beardWS6's Avatar
What did they flow?
Old Oct 4, 2005 | 02:26 PM
TSDuke's Avatar
Originally Posted by beardWS6
What did they flow?
Flow sheet is at the house. I will post up the numbers when I get off work.
Old Oct 4, 2005 | 02:31 PM
Snafu's Avatar
about time!
mine should be done this weekend
Old Oct 4, 2005 | 02:46 PM
NOSjohn's Avatar
Restricted User
Install that stuff quick! I want to see dyno or track numbers! Is that a FAST intake I see?
Old Oct 4, 2005 | 02:49 PM
TSDuke's Avatar
Originally Posted by Snafu
about time!
Yeah, it is about time, but hopefully worth the wait. Can't wait to hear your results. I wish you were closer to me, I want to get these things on NOW!!
NOSjohn, I wish it was a FAST, but the box has a LS6 intake in it. I bought it used, so thats what I picked it up in.
Old Oct 4, 2005 | 03:21 PM
black01_WS6's Avatar
those heads look pretty dam good, also interested in flow #'s
Old Oct 4, 2005 | 04:10 PM
cowboysfan's Avatar
they look awsome.
fuerzaws6
Old Oct 4, 2005 | 04:56 PM
White.Lightning's Avatar
Looking to do the AFR 205's and LG G5X3 112. I will keep my eye on this thread for #'s. Good luck
Andy
Old Oct 4, 2005 | 06:54 PM
TSDuke's Avatar
Ok guys, flow #s are as follows:
Lift Intake Exhaust
0.1000 87.5 67.2
0.2000 158.7 108.2
0.3000 230.5 162.0
0.4000 264.5 193.4
0.5000 289.3 217.8
0.5500 300.5 224.9
0.6000 299.2 232.7
0.6500 297.1 234.5
Old Oct 4, 2005 | 07:11 PM
oange ss's Avatar
not too shabby for a sloppy weld job
Old Oct 4, 2005 | 10:22 PM
TSDuke's Avatar
You're right, I should've bought your ported heads. So, how many heads have you done to date?
Old Oct 4, 2005 | 10:27 PM
Thanks for posting up the #'s
Old Oct 4, 2005 | 11:32 PM
oange ss's Avatar
Old Oct 4, 2005 | 11:42 PM
Snafu's Avatar
I know the feeling trust me! I clayed the cylinder tonight and checked PTV...my best measurements put me over .100" so it looks like I got the greenlight to finish this baby up. I'll be working on it evenings this week and should have it ready to fire up this weekend...hopefully I'll be able to get over to CAM for a tune on Monday.
I can't remember are those 241 (LS1) or 243 (LS6) heads? The flow numbers look like LS1. Yours are slightly better than mine but not by too much...happen to know your runner size?
Have car will travel...you're not too far. Let me know when you plan on doing it and I'll see if I'm available. The tear-down is pretty simple but requires some grunt work and cleaning out the block which is time consuming (and very important). I'm guessing you're going with stock gaskets so you don't really have to measure PTD height to set quench, and if that's the case your PTV clearance should be fine...so mostly you'll just be bolting everything back up without too much complication. Anyway, let me know.
Old Oct 5, 2005 | 08:17 AM
TSDuke's Avatar
These are 241 heads. I don't know the runner size off the top of my head, I'll post up after lunch. He sent me a set of FelPro gaskets with the heads. The PTVC should be fine, but I'd like to check to be safe.
Maybe next weekend?
Old Oct 11, 2005 | 06:57 PM
TSDuke's Avatar
Snafu, here is the runner sizes.
Intake - 217
Exhaust - 80
Old Oct 11, 2005 | 07:00 PM
pdd's Avatar
pdd
congrats
Old Oct 11, 2005 | 07:04 PM
Brian Tooley Racing's Avatar
It looks like the "mixture motion dam" or "swirl dam" has been removed, that makes the port VERY close to the water jacket, was that area welded? If not were they pressue checked? Just curious.
Old Oct 12, 2005 | 08:41 AM
TSDuke's Avatar
I'm pretty sure that is a build up of the thermal coating that's applied to the combustion chambers.
I'm going to cantact them today to find out for sure. Thanks for the heads up.
-Tucker
