LS2 Questions
Old Oct 5, 2005 | 05:48 AM
XTrooper's Avatar
Default LS2 Questions
I haven't taken the time to check into these new motors much yet, so I have a couple of questions.
1. Can someone tell me the stock bore x stroke for the LS2?
2. Is it now possible to install an LS6 or other intake manifold onto the LS2? What TB would/could you use and how would you go about doing it. I know the bolt pattern is different between the LS2 and LS1/LS6 TB's.
Thanks!
Old Oct 5, 2005 | 09:06 AM
DrkPhx's Avatar
1. 4.00 bore x 3.62 stroke
2. Yes. But if you install the LS6 intake you need to stick with a 78mm TB, unless you use the TPIS oval setup. The FAST/Nick Williams setup is the way to go for the LS2. Bolts right on.
Old Oct 5, 2005 | 09:25 AM
GuitsBoy's Avatar
The ls6 intake outflows the ls2 intake, but like it was said, it limits you to a 78 mm TB.
Old Oct 5, 2005 | 09:40 AM
XTrooper's Avatar
Understood. Thanks, men!
