Eagle crank w/ pilot bearing problems HELP
Old Oct 8, 2005 | 07:43 AM
destroyerSS's Avatar
Default Eagle crank w/ pilot bearing problems HELP
Installing my 408 last night when around 11:30 we found that the pilot bearing for my stock crank is to small and is loose in the eagle crank What can be done?? Car is a 98. Anyone else have this problem and how did you fix it?? There must be a bearing that fits!!
Thanks Shawn BTW i am heading back down to finish as much as possible and to get some pic's
Old Oct 8, 2005 | 07:56 AM
1BADAIR's Avatar
PM kaneman he had the same problem and ended up using an older sbc bearing I believe.
Or call 586-741-0158. They have made a few custom bushings to deal with the issue.
