PRC LS6 heads?
When i searched the forums I didnt find any reviews about them. I'm guessing the LS6 has around 10.5 CR on stock gaskets without milling?
thanks and help is appreciated
i looked again at the PRC 5.3 stage 2.5 too, i really dont want much compression, is there a thicker layer gasket i could use to lower it a bit?
Bad idea.
Just use a Ported LS1 243 casting.
The thicker gasket is one of the worse ways to lower compression.
The LS6 heads are working pretty well right now, we're trying a few more tweaks in search of some additional flow, but the last set flowed 260cfm @ only .400" lift!!
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
