Biggest cam for a stock motor??
1- what is the biggest size cam one can put in a stock LS1 (piston-valve clearance wise) and
2-what kinda duration/lift is the max/best for stock heads? Of course this would all be complemented with new valve springs and such.
3- I've heard people say the stock pushrods are not the greatest, is this true and what brand valve train is most prefered by u guys for the LS1?
I had the cc 305 cam in my 97 z28 and thought for the buck it was a nice cam but for the LS1 what cam is the cat's *** on stock heads??
Thanks
As for how big?
Well that depends, whats it for? With the additional bolt ons some cams may get you near 450rwhp, but that doesn't mean it'll be the fastest car out.
You need to have a sensible spread of power and low end grunt for a street car. If it's an out and out racer it's slightly different.
For more info look in the internal engine forums and try speaking to some of the manufactures or sellers. Try the sponsors at the side -----> of the screen. Many sell cams and carry info on them.
And state what your goals are and any mods you already have.
390rwhp with a midler cam may yeild better results for you purpose than 450rwhp+ with an out an out race cam that doesn't produce any power below 4500rpm.
Have you read the cam guide sticky?
Is your engine stock, or the car? If the car is stock you need a lot of other mods before you jump in with a cam.
whats your goals for the car? be honest.
its almost pointless to throw a t-rex in an otherwise stock car, if all you want is lope get a GM hotcam and tune the idle speed down a little.
I took time off from tech due to the increasing number of the same "what cam" threads and the board getting slower.
Came back and it seems even worse.
if everything works out, ill have a x1 soon
good luck with your choice
Hmmmmm thats funny, I usually don't figure LS1(or even LT1 owners for that matter) doubt all possible potential for their cars, but hey, to each his own.
http://thunderracing.com/customersca...cid=36&x=8&y=8
"Rodney's car has been raced to a best of 10.433 @ 130.19 mph with a 1.401 sixty foot time. All of this was accomplished on the stock rods, pistons, crankshaft, and cylinder heads. He is the current "camshaft only" ET record holder for LS1 vehicles in the country. "
Ummm... I thought the cam only record was a tie at 10.295?
correct... it's 10.2xx (not sure of exact) ... It's either shared by 01-z and Magnus or it's very close.... Magnus was running a G5X4 at the time I believe and I think 01-z was running a Trex ... both stock heads
Thunder just hasn't updated their webpage...gee I wonder why?
Is Rodney the only one of those three with an M6? I know 01-z has a 5500 stall three speed...(is it TH350 or 400)
and then some.
i wasnt trying to be an *** at all, im just saying you should be honest with yourself about your goals, or you'll be unhappy in the end with your car in the end or at worst have to do it twice or more to get where you want.
hehe
