how do you determine lobe base circle?
Old Oct 11, 2005 | 09:31 PM
Wades SnS's Avatar
Default how do you determine lobe base circle?
Just wondered if there is some way to determine intake and exhaust base circle without a cam card. The only information I have is .602/.602 236/236 112+2
Old Oct 11, 2005 | 09:41 PM
2xLS1's Avatar
You measure it with a mic or calipers.
Old Oct 11, 2005 | 09:51 PM
Wades SnS's Avatar
I really didn't want to remove the cam to measure it. Is there another way?
Old Oct 11, 2005 | 09:57 PM
Taspeed's Avatar
not that i know of
Old Oct 11, 2005 | 10:17 PM
2xLS1's Avatar
The specs look like Comp XER lobes. Call Comp Cams tech. You could try and PM Unaffiliated Racing. He works for Comp, but he hasn't been on the board here in about a month. I'll PM you his contact info.
Old Oct 11, 2005 | 10:19 PM
Wades SnS's Avatar
yes it is a comp xer lobe just was wondering if there was a way to determine without waiting to call tommorow
Thanks for your help
..RJ..
Old Oct 11, 2005 | 10:29 PM
2xLS1's Avatar
I do know that a 224 XER lobe has a 37.5mm or 1.47in dia. base circle. Yours should be close if not slightly less.
Old Oct 11, 2005 | 10:32 PM
jrp's Avatar
jrp
SN95 Director
my guess its close to 1.45, though as stated you'll want to measure.
