crane 832 and trex
Old Oct 13, 2005 | 06:12 PM
tals1ws6's Avatar
Default crane 832 and trex
I have a set of 832's and wanted to know if they will be ok with a trex every one recommends 921's or prc will I be ok?
Old Oct 13, 2005 | 06:22 PM
MKS's Avatar
MKS
if you have them then use cuz they are good to .650 lift but i think you'll need the Crane 144661 Titanium Retainers to work with those springs
Old Oct 13, 2005 | 06:23 PM
black01_WS6's Avatar
no go with the 921's or go with partiot performance dual vale springs. The t-rex is a high rpm cam and will kill the 832's.
Old Oct 13, 2005 | 09:56 PM
jrp's Avatar
jrp
SN95 Director
just shim them for proper seat pressure and you should be fine.
Old Oct 14, 2005 | 06:15 AM
vettenuts's Avatar
Shimming the Cranes with 0.060 will give you better seat pressure and load at lift than the Patriots, but I am not familiar with the peak lift on this cam. You also need to check for coil bind as well if you shim.
Old Oct 14, 2005 | 12:05 PM
tals1ws6's Avatar
cool thanks
Old Oct 14, 2005 | 01:51 PM
vettenuts's Avatar
If you shim them, Crane doesn't make a shim for them but Comp has one that fits. Look at page 355 in their catalog, part number 4748-16.
Old Oct 15, 2005 | 07:48 AM
smask04C5's Avatar
4753 comp gives you a set of 16 .015,.030 and .060 to afford combinations
