Need help on CR and piston choice
Old Oct 19, 2005 | 07:21 AM
White.Lightning's Avatar
Default Need help on CR and piston choice
I am not sure as to what pistons and head gasket I should be running to achieve my goal of 8.5-9.0:1 CR. It will be a 347ci, stock crank, Eagler H beam rods, Ross/Wiseco/Diamond piston, Z06 cam, Cometic gaskets (unsure of thickness), stock 6.0L heads mildly ported and polished, Carb style intake, 90* elbow to a 90mm Nick Williams TB.
Power adder is a D1SC pushing 15 'ish psi through an M6/Spec4/12bolt.
Current engine mods are: FLP LT's, catted ypipe, Borla catback (open), Z06 cam
(Irrelevant mods are: Whiper lid, Z06 intake, ASP crank pulley, Z06 clutch)
Questions are: (to achieve my goal CR of 8.5-9.0:1)
1. Which piston should I get and what size valve reliefs (brand and PN# would be helpful)?
2. Which thickness head gasket should I get?
3. Should I upgrade the current valve springs that were installed when the Z06 cam was put in for some Comp or Crane springs?
Thanks
Andy
Last edited by White.Lightning; Oct 19, 2005 at 05:43 PM. Reason: 6.0L heads added
Old Oct 19, 2005 | 05:44 PM
Well word on the street is that by adding the 6.0L heads and GM MLS, the compression drops by nearly 1....so that would put me right at 9.0:1 roughly. I will see how that works for the interim.
Andy
