Vinci 062 cam
Old Oct 31, 2005 | 08:37 AM
Ragtop 99's Avatar
Originally Posted by mrr23
i don't dyno with it locked. because i don't run it that way.
A dyno is a tuning tool. You should run it locked so that you can properly tune the A/F and spark in your 3000 - 4500 rpm range. This the range that determines how much torque your converter sees off the line and has a major impact on 60'. If you don't lock it, your converter flash goes right past that range. After you tune that range, then you can dyno unlocked to dial in the A/F and spark on the top end.
Old Oct 31, 2005 | 07:02 PM
FedZ's Avatar
mrr23.......you need my LS6 intake......
mrr23's Avatar
you need a FAST intake first.
Old Nov 1, 2005 | 08:59 PM
mrr23's Avatar
sound clips with the vinci 062 cam i just put in.
rev in park
idle in park
idle in drive
Old Nov 2, 2005 | 04:21 AM
vettenuts's Avatar
Are you still running stock heads?
Old Nov 2, 2005 | 01:56 PM
mrr23's Avatar
haven't since 1/14/05.
