top dead center question
Old Oct 27, 2005 | 06:15 PM
pdd's Avatar
pdd
Default top dead center question
i have a ati superdamper with the 360 degree markings. do i get piston number 1 to top dead center and put the ati damper with the "0" straight up?
any tricks to get top dead center on that piston with the heads on? once i get number one piston to top dead center, how many degrees do i spin the crank for the next piston in the firing order to get it at top dead center?
Old Oct 27, 2005 | 06:30 PM
davered00ss's Avatar
Moderator
ls1howto.com They explain it in the cam install section. Turn the crank pully 45 degrees for each rotation. 2 pistons are TDC at once. You can also stick something in the spark plug hole to determine when the piston is TDC.
Old Oct 27, 2005 | 06:43 PM
vettenuts's Avatar
All depends on how you want to set it. Make sure you read the instructions on honing and measuring the hub and the crankshaft, they have to have a very specific interference fit. Did you get the pin kit? Great time to do it since the hub is already keyed.
Old Oct 27, 2005 | 10:09 PM
Beast96Z's Avatar
I slide a zip tie into the spark plug hole and role the motor over till I feel the piston come up. You could also use a piece of coat hanger if you need more "feel". Repeat on each cylinder doing 2 cylinders at a time. The guide on LS1how to tells you which will be at TDC at the same time.
