quite cams
Old Oct 28, 2005 | 02:17 AM
FormulaFirehawk520's Avatar
Default quite cams
can anyone tell me what cam is out there with the most peformance with out being able to hear it lope? i was thinking ls6 cam but can anyone tell me anything better? thanks
Old Oct 28, 2005 | 02:25 AM
wildta's Avatar
lingenfelter GT2-3 cam
Old Oct 28, 2005 | 02:40 AM
Predator's Avatar
I have a 224/224 112, and it sounded pretty lopey with a Loudmouth exhaust. I switched to a Hooker cat back and you can barely tell I have a cam. My point is that your exhaust system has a large say in how loud/lopey your cam will sound.
Old Oct 28, 2005 | 03:03 AM
does it have any lope to it and what kind of gains would i see
Old Oct 28, 2005 | 03:06 AM
i was going to put headers on and leave the stock catback except for a cutout before the axle but i have no problem leaving it closed. and also is there any point to put headers on and leave the stock catback
Old Oct 28, 2005 | 03:53 AM
Predator's Avatar
Yeah, you'll make more power with headers, even with the stock exhaust.
Old Oct 28, 2005 | 03:58 AM
goober35's Avatar
With that cam u cant tell the car has anything done to it. The only way you can tell it is there is if you have LT's and u stick your head under the hood.
I installed LT's Shaner2 and GT2-3 and gained 50rwhp over stock in an A4
Old Oct 28, 2005 | 04:09 AM
loloone's Avatar
LS1Tech Editor
I've heard Thunder Racing's Cheater cam through some long tubes, an OR Y-pipe and a Magnaflow, and it didn't really lope to much more than stock. High spinning cam too.
I might consider it for mine.
-J-
Old Oct 28, 2005 | 04:53 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
It is because the LSA is a little higher I believe. But so is that old man camshaft that Thunder offers as well. You should check into those 2 for sure.
Old Oct 28, 2005 | 04:58 AM
Brandon Smith's Avatar
Thunder racings cheater cam is close to one of the biggest cams you can get and tune it so that it doesnt have any lope and still sounds stock
Old Oct 28, 2005 | 09:56 AM
jub jub's Avatar
I think the LS6 (02+) cam is a pretty good cam and you can probably find one pretty cheap.
Old Oct 28, 2005 | 12:09 PM
NviouSS's Avatar
there is no lope at all. if you don't have headers you can pick up around 30 rwhp.
Old Oct 28, 2005 | 12:16 PM
S1LV3R's Avatar
You will leave power on the table with the stock catback. Check out my sig. A catback is the only thing I'm lacking. Of course the car is very docile and you could probably sneak up a few people especially with one of the cams mentioned in this thread.
Old Oct 28, 2005 | 12:40 PM
Ragtop 99's Avatar
You can hide the lope of a 220/220 114 with a 850 rpm idle and a stock exhaust. With a 900 rpm idle you could hide a 224/224 115 cam.
Old Oct 28, 2005 | 12:45 PM
what is the performance difference between that cam and the lingenfelter GT2-3 cam
Old Oct 28, 2005 | 12:47 PM
i was looking and the LS6 CNC ported heads by lingerfelter they said that that cam works great with those head but would it be noticeable that i had aftermarket head?
Old Oct 28, 2005 | 01:18 PM
Are you trying to make a sleeper?
Old Oct 28, 2005 | 01:41 PM
the best that i can
Old Oct 28, 2005 | 01:47 PM
wildta's Avatar
Why not just have your ls1 heads ported ? + gt2-3 cam !
Old Oct 28, 2005 | 01:49 PM
wildta's Avatar
Also you could do a stroker motor depending on $ +cam+ls1 ported heads ?!!
