Low Oil Pressure
I do have some oil pressure.....15#s at idle and 20#s at 2000 rpm. Tonite I pulled the filter and changed the oil and didn't see any metal in the oil other than a touch of filings on the magnet. I will cut apart the filter tomorrow morning. Other than a missing chunk of a bearing (I hope not since nothing in the oil so far) what could cause the low oil pressure.
The pressure relief valve above the filter seems to be working. I also pulled the Oil sensor and it is clear. Any chance the pressure relief valve in the pump itself is the culprit?
Perry
Perry
Next step is to pull the cover and check the oil pump and pressure relief valve there. There is oil pressure but right at Helms stated minimums and the engine has had good indicated pressure up to now (5 months of street driving), which is about double/triple Helms minimums.
Will keep everyone posted.
Perry
Perry
