Urgent! Any difference between 98 & later ls1 short blocks?
Old Jan 15, 2003 | 08:13 PM
1bad2k2ta's Avatar
Default Urgent! Any difference between 98 & later ls1 short blocks?
I need a quick answer because I have found a 98 shortblock and t56 for cheap!
Is a 98 short block the same as all other model years?
How about the M6 tranny?
Thanks
Old Jan 15, 2003 | 11:13 PM
1bad2k2ta's Avatar
Default Re: Urgent! Any difference between 98 & later ls1 short blocks?
ttt
Old Jan 16, 2003 | 06:52 AM
GeorgeC's Avatar
There are some minute differences, but the one concern you should have would be the crank position sensor. 97-98 used a different reluctor wheel on the crank and a different sensor. As long as the crank and sensor are matched properly, you shouldn't have any issues (the pin-out and signal are the same, AFAIK). Just make sure the shortblock you're looking at either has the CKP sensor in it already, or order one for it.
Off hand, I can't think of any more compatability issues...
Old Jan 16, 2003 | 06:19 PM
1bad2k2ta's Avatar
Thanks George. I have also been reminded that these blocks can't be bored.
Old Jan 16, 2003 | 08:01 PM
Ferrell's Avatar
George, who did you order your 382 through and is there anyone local that you trust to work on the car? I'm down and the 382 is looking good.
Thanks,
Ferrell
