Need help with heads, what to get!!!!!
Old Nov 2, 2005 | 03:45 PM
n20stroker's Avatar
Default Need help with heads, what to get!!!!!
I need a set of heads that wont break the bank.
i have a set of gtp stage 2. the problem is they worked well with my 346 stock bottom end, but with the 402 my compression is to low. i need a set of heads that will work with my trex cam, or would it be better to just mill the heads to reach 62cc.
thanxs
Old Nov 3, 2005 | 07:10 AM
n20stroker's Avatar
soo what no one knows of a set of good heads that will work with 402.
Old Nov 3, 2005 | 12:26 PM
ls1408cp's Avatar
I am using 240 ets on my 408 they break the bank though
Old Nov 3, 2005 | 12:35 PM
Z'mnypit's Avatar
Im using the Patriot stage III LS6 heads on my 408. They are awesome so far. BTW- the combustion chambers on my heads are 62cc unmilled. With the stock thickness gasket, -15cc diamond pistons, I have a CR of 10.7-1. What kind of CR are you looking to get?
Old Nov 3, 2005 | 01:09 PM
STRIPSTAR's Avatar
Mill your heads isnt a bad way to go. Milled AFRS, Darts would be nice but more $. You can buy a nice set of milled 5.3 heads cheap and sell yours to make alot back.
Old Nov 3, 2005 | 01:10 PM
n20stroker's Avatar
well im looking for about 11.0 or soo. im using -12cc dished pistons from mahle
also using stock heAD GASKET,im going to use after market gaskets when i change the heads. i think my comp now is like 10.2 os soo with my heads there 66 cc stock gasket.
Old Nov 4, 2005 | 03:31 AM
Crazy Man's Avatar
If I had a 402 id probly put all pros on it.
Old Nov 4, 2005 | 05:11 AM
stevemilz's Avatar
Dart 225
http://www.dartheads.com/ls1.aspx
http://www.dartheads.com/manager/uploads/LS1Flyer.pdf
Old Nov 4, 2005 | 07:04 AM
n20stroker's Avatar
thanxs for all your input im liking the darts well see what happens
