Why use a reverse split Cam?
You have been on this board long enough to know a little something about valve events.
Bottom line is that if you look at the amount of overlap and where it is in relationship to TDC, our 230/236 will definitely make more PEAK power, but not necessarily more area under the curve. Again based on past testing either of these cams could be either forward or reverse split and basically do the same as they are already doing. EVERY internet 'expert' knows the reverse split 'doesn't work' so we made this one a forward split. IMHO the exhaust opening point is probably the least sensitive parameter for a properly tuned header system on a street motor. Your mileage may vary, J/K
.Didn't you get the memo??? Peak power is all that matters!
https://webspace.utexas.edu/wl333/lastdyno.jpg
FYI...just looking now because I stilll need to get other mods like headers/ory and all the goodies to swap a cam....springs, pushrods...ect.
You pick the right reverse split cam, and it'll make you happy....
Red = Borla, free mods, lid
Blue = Full bolt on
Black = TR230 on w/ 853s
All were tuned pulls, all were SAE #s, all were previous dynos of mine
Were the 853's not on the previous combos? Any advantage to them?
Blue = Full bolt on
Love the reverse split!
