help
What your next mod should be really depends on what your goals are. Generally, building up your engine or suspension to handle your final goal is a good next step. If you are only looking to stay within numbers that can be had on a stock block, a mild cam or low boost F/I setup may be a good choice. Just my $.02.
Also is the car A4 or stick? Maybe a torque converter if your A4.
