Drilling holes in your lifter retainers
Old Nov 22, 2005 | 12:51 PM
FastKat's Avatar
Haha I don't think Phil's afraid of a little engine speed!
Originally Posted by GrannySShifting
I dont think its goign to matter much at all unless sustained high rpm motors
Old Nov 22, 2005 | 04:01 PM
bulletLS1's Avatar
I did my drilling also, no mishaps, but the lower part of the trays where full of gunk, thick, black soothy, (I use good quality oil) and the trays where very difficult to clean also the flashing from the plastic must be cleaned, deburred and all sharp edges cleaned with dowel and sandpaper, and be REALLY shure not a small spaec of plastic CAN fell to the oil::::
Old Nov 23, 2005 | 04:28 AM
eallanboggs's Avatar
Do you drill both sides of the retainers? If you only drill one side do the holes you drill go toward the valley side or to the outside or does it even matter?
Old Nov 23, 2005 | 08:32 AM
Dixit's Avatar
Drill on both sides
Old Nov 23, 2005 | 08:51 AM
Teutonic Speedracer's Avatar
I understand that you only drill out one side, and the postion is important too. Are you guys drilling out the LS2 lifter trays also. I have some on the way and understand they are beefier and fit the LS1.
Old Nov 23, 2005 | 09:45 AM
427's Avatar
427
We normally just drill one side. We face the holes toward the piston side, so the oil will run out of the retainer back to the pan.
Kurt
Old Nov 28, 2005 | 10:10 AM
bulletLS1's Avatar
OOOOPS! two sided hole!
Old Mar 13, 2008 | 04:10 PM
98LSZ28's Avatar
any dimensions on where to place the hole? ie: distance from top of tray and off centerline?
Thanks!
Old Mar 13, 2008 | 04:19 PM
bjamick's Avatar
Thanks!
I would guess just make sure the holes are even and it prob wouldn't really matter as long as its somewhat centered.
Old Mar 14, 2008 | 12:36 AM
405HP_Z06's Avatar
Thanks!
Here is what I did. I posted a thread on this subject a short while back.
See: https://ls1tech.com/forums/generation-iii-internal-engine/848915-lifter-retainer-modification.html
Measurements: Note: I only drilled one side, the background makes it look like I did both sides.
Old Mar 14, 2008 | 03:46 AM
98LSZ28's Avatar
Thanks! Gonna do mine tomorrow! need all the oil flow I can get!
Old Mar 16, 2008 | 04:39 AM
  #32
TransAmcoupe98's Avatar
I did the drill in my retainers, supports quicker drainage out. I put 2 in each side.
Old Mar 17, 2008 | 11:39 AM
  #33
radkon's Avatar
I won't say don't do it but I will state that this "mod" is intended to prevent oil starvation in "sustained high RPM" engines. In esscence you are allowing oil to drain out of the lifters and return to the pan faster. If you are tracking the car every once in awhile toss an extra half quart of oil in the pan and call it a day. Me, I prefer to have my lifters well oiled.
Just my $.02, which like anything based on the dollar anymore isn't worth much
Old Mar 17, 2008 | 04:24 PM
  #34
flynlow3's Avatar
I did. I read it as well in the how to build a high performance ls1 book and chose to do it while i was in there. Cant hurt right?
Old Mar 26, 2008 | 03:55 PM
  #35
fastvet's Avatar
I'm about to do it today, If I **** up, then I will be leaning towards you all for spares! HAHA!
Old Mar 26, 2008 | 05:39 PM
  #36
405HP_Z06's Avatar
As long as you use a Unibit, it will be fine. If you use a 1/2" drill bit, all bets are off.
Old Mar 26, 2008 | 07:02 PM
  #37
jsteele90's Avatar
little extra oil never hurt anyone!
Old Mar 26, 2008 | 07:36 PM
  #38
DrkPhx's Avatar
I used masking tape on the surface of the tray and used a 1/8" drill to start. Then went right to a 1/2" bit with no problems or cracking.
Old Jul 15, 2008 | 09:35 PM
  #39
ibjamin's Avatar
I'm doing this today.
Just a heads up> Those dimensions shown on the photo ARE NOT CORRECT!!! Don't use the 1 5/16" dimension shown. The actual measurement should be about 11/16" for what is shown. The 1/2" dimension is correct.
George
Old Jul 16, 2008 | 12:22 AM
  #40
405HP_Z06's Avatar
George
Thanks George, I made a note and misread my handwriting. I corrected the image.
