Question regaurding more cubes with rebuild
Old Nov 10, 2005 | 08:52 PM
Superman09's Avatar
LS1Tech Sponsor
Default Question regaurding more cubes with rebuild
Hello. Well i plan on going FI here in the future. I am pretty set on a nice front mount turbo kit. I plan on running about 6-8 psi o nthe stock block and what not. Than i know FI is addictive and ill want to up the boost. I got a quote of $6 to pull my engine, forge bottom end, install new cam, rebuild/install it in car and tune it. Now what if i want some more cubes too? Is it possible to like get my stock ls1 block bored out to a 383 so i can have some more cubes or how does this work and whats a relative extra cost to upgrade to bore my block to a 383? Thanks
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Nov 10, 2005 | 09:02 PM
Grimes's Avatar
you could get a stroker crank, but you can't bore out the aluminum block; only clean it up a tiny bit. A 4" crank with stock bore would give you your 382
Old Nov 10, 2005 | 09:06 PM
67Ranger's Avatar
for that much bore, you would have to go sleeved, i believe. A cast iron bored 30 over will come out to about a 369-370, and i think you can go a little bit more than that, if you wanna get real wild with it.
Old Nov 11, 2005 | 05:30 AM
Superman09's Avatar
LS1Tech Sponsor
Well i was jsut curious how easy it is to jsut get more cubes from building my motor. What is about the max i can go before it starts getting crazy, unreliable, and a ton of cash. What approx price will it cost to get to this max CI without going crazy? Thanks
__________________
Old Nov 11, 2005 | 07:44 AM
GuitsBoy's Avatar
Why not check the sponsors. Theres a few with 402 aluminum blocks from 3800-4200 or so. The iron blocks are even cheaper.
Old Nov 11, 2005 | 12:33 PM
Superman09's Avatar
LS1Tech Sponsor
Yea well thats for the short block. 402 short blocks are rouglhly 4-5 grand ish ive found, than plus some AFR heads ($2200), valvetrain ($1000) 90/90 portmatched ($1250), and all the other junk plus install, tune and what not, it seems to come out around $12 grand ish every time. I can get my shortblock bedone with new valvetrain for $6 grand. What do you suggest?
__________________
Old Nov 11, 2005 | 12:39 PM
calongo_SS's Avatar
either spend the extra money or stay stock cubes. It's not gonna be cheap to go to anything > 400 cubes. cheapest route other than stock cubes is a longer stroke, stoock bore.
Old Nov 11, 2005 | 01:54 PM
Grimes's Avatar
If you are going to go FI anyway, just change out your rods and pistons. Keep the stock crank. If you are going to get a forged crank, get one with a 4" stroke.
Old Nov 11, 2005 | 02:05 PM
GuitsBoy's Avatar
What grimes said. No sense going larger cubes if youre doing forced induction. Harlan pushed his stock crank over 1K HP. Just do the pistons and rods. Buy a used crank if need be.
Old Nov 11, 2005 | 02:56 PM
PortPros1's Avatar
You can go to a 383 without having to resleeve, 3.908 bore with a 4.00 stroke.
But if your running a turbo stay with the stock cubic inches and just run good parts. The turbo will make a bunch more torque and HP you won't need the extra inches.
A good forged rotating assembly will run you about $2800.00, plus balancing. If your going to run more than 6 or 8 lbs of boost I'd upgrade your pistons. You'll spend a bit more now and not have to worry about whether your pistons will hold up or not later, when you turn up the boost...
