BMW boy needs help with v8 decision+mods
Old Nov 13, 2005 | 04:07 PM
david_rg79's Avatar
Originally Posted by cenTX-LS1
Bring on the spell check.
Thank you soo much for your helpful post
Old Nov 13, 2005 | 04:18 PM
david_rg79's Avatar
Originally Posted by strokedls1
Usually number 7 or 8 due to the intake design feeding more air to thse cylinders and running leaner. If your running a lot of power you put more strees on them and could give on some nitrous.
If a direct port setup is done, would intake manifold design still be an issue?
Also on many nitrous setups i have done for people on stock engines(imports) i used meth instead of fuel on the fuel side, the jet has to be almost two times the size of a normal fuel jet, but allowed for large shots 150-175 on stock 4cyl engines
do you guys mess with meth much?
Old Nov 13, 2005 | 04:42 PM
david_rg79's Avatar
Originally Posted by distortion_69
Josh
wow, thank you for your extensive responce, i had to stop and actually think what you said
BTW i have 4.44rear end, we are usuing a r32 sykline rear end with modded axles, dont remember ratio but it was a low 3something
Old Nov 13, 2005 | 11:27 PM
distortion_69's Avatar
david_rg : Direct port would be the safest way, due to better distribution. On large shots you tend to get uneven distribution which could cause some cylinders to run slightly leaner than other.
However, running a 150 wet shot (biggest shot you can run on a stock shortblock without sacrificing alot of reliability).. this is not necessary.
Honestly, a 150 wet shot on top of a 400rwhp cam only setup is going to be sick at that weight and offer the best bang for the buck. Other things such as heads, will kill your horsepower per dollar ratio. Besides, if your like me.. the closer you can keep it to stock.. the more reliable it will be.
Peace,
Josh
