LS6 Pushrods?
Old Nov 11, 2005 | 04:55 PM
Worm's Avatar
Default LS6 Pushrods?
Whats the deal with the LS6 is there something different in the heads or is it just the base circle of the cam is different? Because the LS6 has 7.35" versus 7.40" pushrods? So if I go with a 224/228 cam or a GT2-3 cam do I need the 7.40"? I HEARD you needed a longer pushrod for the LS6 cam, but the LS6 has SHORTER pushrods than the LS1 right?
Old Nov 11, 2005 | 08:18 PM
TA TECH's Avatar
Correct me if I'm wrong but I believe the LS6 valves are shorter and require the shorter pushrod!
Old Nov 11, 2005 | 11:22 PM
kenp's Avatar
Pushrods are the same as LS1 - 7.4". I believe the 02-04 lS6 has a cam with a smaller base circle so GM compensated by making the valve stems slightly taller. Technically, I believe the LS6 heads with an LS1 cam would need shorter pushrods. Of course, if you use a thinner head gasket than OEM and/or you mill the heads, you're getting close to being right back to LS1 dimentions. In the end it just might be much-a-do about nothing.
Old Nov 11, 2005 | 11:28 PM
HOSS's Avatar
LS1 head with ls6 cam needs slighly longer pushrod
Old Nov 11, 2005 | 11:46 PM
PREDATOR-Z's Avatar
7.425 to be exact.
You can run 7.40 but your preload will be looser and your valvetrain a little noisier (with stock rockers).
You can adjust with aftermarket adjustable rockers also.
LS6 valves are 6mm taller.BTW
Old Nov 12, 2005 | 09:38 AM
Worm's Avatar
So whats the answer to the question? New cam in a LS6 motor I need regular 7.40 pushrods? Or are you saying I need 7.425
Old Nov 12, 2005 | 09:47 AM
PREDATOR-Z's Avatar
With the cams you mentionned 7.40
If you get .58x>.600 lifts I used 7.425 (less noisy)
Both is assuming stock gasket, no mill
Old Nov 12, 2005 | 08:47 PM
kenp's Avatar
If you had LS1 heads and LS6 cam and you were to shim the rocker stand .025 that would theoretically make you .050 short with the stock pushrod wouldn't it?
