R.E.V. Valve Spring/Retainers questions
Old Nov 13, 2005 | 03:51 AM
transsam's Avatar
Default R.E.V. Valve Spring/Retainers questions
I am getting ready to do a spring swap. I have had the REV springs/retainers on the car for some time now and I considering the engine is coming out, I figured it is a good time to swap considering they have some miles on them and I will be picking up some lift.
Can the REV retainers be used with any other brand of springs?
Thanks.
Old Nov 13, 2005 | 08:46 AM
AdamSS's Avatar
Stay away from REV's. A few weeks ago my friend popped two of them after 10K miles.
He only has a Z06 cam and high-ratio rockers.
He popped two springs on one cylinder, which broke his valve, which shattered the piston. Ha awaits a new shortblock....
Old Nov 13, 2005 | 10:28 AM
PortPros1's Avatar
Thanks.
Go with the Comp Cams 918 springs and retainers, tried and true the best springs for the money.
Old Nov 13, 2005 | 11:47 AM
TAQuickness's Avatar
really depends on the cam as to wether or not the 918's will be adequet
Should work with his 224 cam
Old Nov 14, 2005 | 02:30 PM
transsam's Avatar
I am looking at getting a stroker soon with a mild cam -f14- so lift will be aggressive. I am getting rid of the REV springs, but would like if possible to use the retainers to save a little on the cash. I know the springs are crap, but I can't imagine the retainers are a weakness, so...can I use the retainers with a better spring?
