2.08 intake valve on 370
Old Nov 14, 2005 | 10:58 AM
67Ranger's Avatar
Default 2.08 intake valve on 370
What are the disadvantages of using a bigger valve on the smaller displacement motor?
Old Nov 14, 2005 | 11:21 AM
PREDATOR-Z's Avatar
By no means 370 is small displacement. 2.08 will be fine on that motor. As a matter of fact I wouldn't use anything smaller than 2.05's. That motor will move some good amount of air. Bore size will not shroud the intake valve.
Old Nov 14, 2005 | 11:41 AM
67Ranger's Avatar
alright. I already bought the heads, but then i was reading about most people going with the 2.55, and i wasnt sure if there was something wrong with goin with 2.08s. Also, Is there a writeup on the molding clay method to check valve clearance?
Old Nov 14, 2005 | 12:49 PM
PREDATOR-Z's Avatar
Clay is innacurate for the size of cams that some of us put in there.
The most accurate way is to use a dial indicator method.
Old Nov 14, 2005 | 02:53 PM
Haans249's Avatar
Could you elaborate how to use the dial indicator method. or provide a link with a write up?
How much clearance do you think you can have with 2.055 intake and 1.57 exhaust on a stock LS1? What size cam would fit?
Old Nov 14, 2005 | 11:05 PM
PREDATOR-Z's Avatar
https://ls1tech.com/forums/generation-iii-internal-engine/240703-tell-me-if-i-mearsured-p-v-right.html
Hope this helps.
Old Nov 15, 2005 | 12:37 PM
Haans249's Avatar
Originally Posted by PREDATOR-Z
TY, finally someone who steps up with a little help.
Much Appreciated. How did you get a Camaro all the way over there to the UAE? I was in Qatar 1.5 yrs ago for a break from Iraq, rich country I might say haha.
Adrian
