will this cam work for me?
i have a 4k stall, stock 3.23 gears, stock intake
EDIT: if possible, does anyone have the specs on this cam? or dyno graph?
Will it work for you.....??? Well, it'll run, if that's what you want to know.
It will idle moderately rough, and is small enough that your stall and gears should be okay. Longer exhaust duration will be good for forced induction.
Other than that... Just have to do your homework. (or at the very least tell us what you want to end up with)
and spec, the cam is going to run its best w/ an ls6 intake, ported TB, and a pulley... remember,you got hook ups
as for hte intake, still searching. I just want to know if this cam will do what im looking for, IE: stay in my shift extension. b/c if it doesnt, then its not worth getting.
