Those with ARP Head Studs....
Old Nov 17, 2005 | 02:59 AM
CAT3's Avatar
Restricted User
Default Those with ARP Head Studs....
Is it a PITA to get the heads off or not that bad? I know it will save time cleaning bolt holes, which is a big bonus.
Charlie
Old Nov 17, 2005 | 08:00 AM
JoeyGC5's Avatar
F-body, yes, my Vette not as bad.
Old Nov 17, 2005 | 09:18 AM
Dixit's Avatar
I did my Z06 and dont have studs (wish I did instead off the ARP bolts) but its really easy to get to all the head bolts and pulling the head off. Fbody, thats another story.
Dixit
Old Nov 17, 2005 | 09:56 AM
RPO_Z06's Avatar
I have studs and its easy but I'm not an F body but I hear its not a problem either.
Old Nov 17, 2005 | 10:15 AM
1Bad RamAir's Avatar
My head gasket blew and have the 1/2 head studs and was able to remove without a problem.
Old Nov 17, 2005 | 01:06 PM
pekkaz's Avatar
I have ARP head studs in f-body and I've pulled and installed heads number of times with them. You just need watch a bit so you won't scratch the heads. In PITA scale it's 10x less PITA than cleaning the bolt holes for TTY bolts.
Old Nov 17, 2005 | 03:51 PM
ArcticZ28's Avatar
Old Nov 19, 2005 | 12:44 AM
CAT3's Avatar
Restricted User
Cool, glad I went with the studs then. I am used to working PITA, but cleaning bolt holesI hate even more!
Old Nov 19, 2005 | 01:56 PM
DanZ28's Avatar
It's no problem on an F-body at all, easy on, easy off..
Dan
Old Nov 19, 2005 | 08:47 PM
Jimbo'sZO6's Avatar
I installed ARP studs when I did my H/C package last winter. IMHO, well worth the extra bucks. Makes head removal/installation a breeze.
Jim
Old Nov 19, 2005 | 09:39 PM
Dixit's Avatar
I shouldve installed studs as well, Im kicking myself because I want to remove the heads again but dont want to deal with the cleaning again, oh well, will have to grin and bear it one more time. This time do studs.
Dixit
Old Nov 20, 2005 | 03:04 AM
LS1FIRE's Avatar
Sorry for being off topic but i am curious to know if there Is a drain plug for the coolant on the block?
Old Nov 20, 2005 | 05:16 AM
CAT3's Avatar
Restricted User
Yes, on the side, you will see a brass looking plug. GL.
Old Nov 20, 2005 | 05:58 AM
LS1FIRE's Avatar
On which side? Near what location? Is it a plug like the oil drain plug? If I ever swap heads again i will remeber to do this if it helps stop the coolant spilling when taking the head off. Thanks
Old Nov 20, 2005 | 11:19 AM
Dixit's Avatar
Well getting to the plug is not easy, many see it as being more of a PITA to get to those two plugs then to just pull the head off and clean up.
I just do that. I have a wet/dry vaccum with micro attachments from sears. That sucks up all the coolant from the chambers and then one of the micro attachments I put a straw on the end and tape it to the attachment. Then just put it down each bolt hole to get 95% of the coolant out. Then just run the paper towels down each hole once or twice to make sure it was clean. Best way so far. The wet/ddry vac I have is the 2.5gal one from Sears.
Dixit
Old Nov 20, 2005 | 06:32 PM
bichin95redta's Avatar
No matter what you decide to go with, bolts or studs, it is ABSOLUTELY IMPERATIVE that you THOROUGHLY blow out/clean ALL blind-tapped holes. ANY liquid trapped in the bottom of a blind hole is a death sentence. When installing the studs/bolts, you'll be trying to compress a liquid, which we all know can't happen; result...cracked block.
I am fortunate enough to have a 2-post lift in my shop, along with some very good friends from my local F-Body car club. For my heads/cam/clutch/intake project, I'm dropping the engine/tranny/K-member out the bottom of the car. This way, everything will be accessible for removal, cleaning, and re-installation. I'm nervous as a ***** in church about my 1st go at an all-aluminum engine, but, like I said, I'm going to have plenty of experienced help.
Good luck to you on your project.
Old Nov 21, 2005 | 10:06 AM
M_T_0's Avatar
the point is that AFTER you install the studs the first time you will never need to clean the holes again, for future head replacments.
More than Zero
Old Nov 21, 2005 | 10:15 AM
Dixit's Avatar
That alone is worth the extra cost for folks who do frequent head removals.
Old Nov 21, 2005 | 10:44 AM
blackws69's Avatar
it's not to bad. just be carefull on the drivers side when installing the heads.
