compression question
Old Nov 20, 2005 | 01:52 AM
GDM Z28's Avatar
Default compression question
what will the compression be with a lq9 block and ls1 heads that were milled .030
TIA
Old Nov 20, 2005 | 07:24 AM
PREDATOR-Z's Avatar
~ 11.5
I assume that you have flat top pistons.
Use this calc: just enter a negative value for piston to deck height. I entered -.007
.030 mill on LS1 should be around 60cc +/-
http://www.rbracing-rsr.com/compstaticcalc.html
Old Nov 20, 2005 | 10:43 PM
GDM Z28's Avatar
Originally Posted by PREDATOR-Z
~ 11.5
ill be using the stock lq9 pistons.
