Mounting dial indicator??
Old Nov 23, 2005 | 03:50 PM
transAm-98's Avatar
Default Mounting dial indicator??
any tricks to mounting a dial indicator to check preload. can't seem to keep it steady
Old Nov 23, 2005 | 04:03 PM
ROCNDAV's Avatar
I had an old steel plate laying around. I put the valley cover gaskets over it and marked four holes then drilled them out. I can bolt it to the top of the block and stick the mag base on the plate.
Obviously this wont work if your valley cover or intake are installed.
