Spring Upgrade
Old Nov 24, 2005 | 07:12 PM
FormulaFire's Avatar
Default Spring Upgrade
I have Patriot Gold Dual Spring in my AFR 205s right now. I will be running a G5X3 114LSA. Will this Springs be alright?? Also.. Should I upgrade Lifters?
Old Nov 25, 2005 | 09:43 AM
dudas35's Avatar
Those springs are fine, if you are pulling the heads replace the lifters, if not keep the stockers unless you have a lot of miles.
Old Nov 25, 2005 | 10:34 AM
I'm sitting at 35k miles right now. And I am doing Heads/Cam swap.. So new lifters??
Old Nov 25, 2005 | 10:50 AM
PREDATOR-Z's Avatar
Yes new lifters.
I would use either Comp Cam 850-16 or Crane replacements.
CRANE would be my choice but as usual they are $275.00 VS $199.00
Old Nov 25, 2005 | 11:04 AM
LS1 BU's Avatar
I used those springs with stock Comp replacement lifters without problems. I only had a couple thousand miles on setup.
