LS6 head porting questions...with pics
Old Dec 12, 2005 | 03:49 PM
Xtnct00WS6's Avatar
Originally Posted by CBX
I am not sure how to proceed with the combustion area. If I just leave this part alone how much flow am I giving up? I don't want to make any mistakes.
I'm not sure about the combustion chamber either. I actually just started smoothing it out though. I'm not really doing any porting in that area, just making it shiny and smooth. I'm afraid of taking out compression.
I did read somewhere that it's better to have the combustion chamber as smooth as possible so things are less likely to attach to it after combustion occurs.
A cutaway of the before and after of the valve bowls would be freaking awesome too btw! Anyone have a cutaway pic of a specific amount of how far to go down?
Old Dec 12, 2005 | 03:54 PM
Bo White's Avatar
Just polish the chambers out and deshroud the valves to the gasket line, thats all I do. More flow can be had to do more work but a flow bench is needed to guide you on this.
Old Dec 12, 2005 | 04:39 PM
CBX's Avatar
CBX
Bo, can you tell me how thick the intake swirl ramps are? I did some smoothing of the corners and I need to know how much to take out. This is what I did so far.
How does it look so far? Thanks
Old Dec 12, 2005 | 08:18 PM
GuitsBoy's Avatar
I have a practice head where the guy before me ported into the water jacket under the swirl ramp. Looks like as viewed from above the bowl its right about even with the back edge of the guide but about 3/8 under the flat ledge behind the guide. I would think you could probably take it down another 1/8 safely from the looks of your pics, but id wait for someone else to chime in
Old Dec 12, 2005 | 08:26 PM
Bo White's Avatar
I chimed in on the other thread, leave everything shape and size wise alone and just blend and smooth(and take the rocker bolt boss out).
Old Dec 12, 2005 | 08:53 PM
CBX's Avatar
CBX
Take the rocker bolt boss right out as in the threads are showing?
Old Dec 12, 2005 | 08:56 PM
Bo White's Avatar
Correct, cut it all the way out so that it looks like it was never there, except the threaded hole being there. Blend it into the existing surrounding wall so its a smooth transition.
Old Dec 12, 2005 | 09:18 PM
CBX's Avatar
CBX
Will do, thanks. That alone has got to be good for a few CFM.
Old Dec 12, 2005 | 09:46 PM
Xtnct00WS6's Avatar
Let me know what you guys think. This is what I have so far:
I basically just smoothed everything out. I took a tiny bit of material off of the area around the spark plug opening too.
Old Dec 12, 2005 | 09:53 PM
CBX's Avatar
CBX
I basically just smoothed everything out. I took a bit of material off of the area around the spark plug opening.
That looks great. What did you use?
Old Dec 12, 2005 | 09:55 PM
Bo White's Avatar
Looks blingy, get a good finish on the exhaust port too(anything finer than 80 grit doest increase flow, just keeps carbon deposits down to a minimum). Intake ports leave as 80/120 grit.
Old Dec 13, 2005 | 10:46 AM
  #32
Xtnct00WS6's Avatar
Thanks! I used a dremel with a wire brush and a bunch of those brillow puff *****. I'll take some pics of them when I get a chance. It seemed to work pretty well.
Old Dec 13, 2005 | 11:31 AM
  #33
Xtnct00WS6's Avatar
Thanks Bo!
Do you think I lost any compression when I reworked the spark plug opening section? Does polishing the combustion chamber (as apposed to leaving it stock) increase flow at all? I'm thinking not, but I'm curious.
Old Dec 13, 2005 | 05:45 PM
  #34
Bo White's Avatar
No flow on polishing but will increase when deshrouding. You may have lost a cc, may not even that.
Old Apr 2, 2016 | 08:24 AM
  #35
chrisp250r's Avatar
Does anyone have a clear answer on what you are gaining by removing the rocker boss? i was thinking about leaving it on a set of 243 heads i'm doing for my ls1 truck, is it worth it to go ahead and knock it out? i was under the impression that the intakes were pretty good and the exhaust was what needed more attention.
Old Apr 2, 2016 | 09:05 AM
  #36
KCS's Avatar
KCS
Moderator
Every ported LS head I've seen has the rocker bump removed. When you remove it, you're removing an obstruction that could cause turbulence in the port and you're gaining cross sectional area in that section of the port. Basically you improve the quality and quantity of airflow.
Old Apr 2, 2016 | 12:54 PM
  #37
spawne32's Avatar
this post is from 2005 lol
Old Apr 6, 2016 | 10:24 AM
  #38
chrisp250r's Avatar
i found it on google, lol... still good info though
